averaging images like this is exactly what happens internally. If you average 5 images with different seed, you will get the same image as if you would render for 5 times longer.
UNLESS…
you average images with gamma on. This is wrong and produces incorrect image (and I think that is what happened - your averaged image is darker). Then you will get biased results, but probably with less noise. This is very similar to vray subpixel mapping on.
I didn’t notice it is darken…(maybe because it is day, maybe in dark room it will be most notable). I just save images form framebuffer, gamma in 2.2 as default, i not touch it for corona render
Anyway, i expected it, i wanted to render test image for 5 times longer, but you already explain all
Well, i just wanted to make something, fail it will be or not.
Txh for explanations Keymaster.
ps
atleast i can use my program for reduce noise from photo… if only i had tripod and remote for camera..
If you own photoshop, then it could be easily aligned. I’m not sure if photos still would be applicable for noise averaging, though. OTOH, pictures shot at base ISO and long shutter speed gives almost as good results as averaging from multiple shorter exposures.
i still need tripod if i want shoot something… not random shit at home.
i dont think i can merge photos with offsets
nevermind, for photography need get out of home (may be go on nature) and it need do, being not alone. (especially in my city). I dont have such opportunity.
