Non-rectangular and multiple render regions at once
Sometimes I need to render a region for an image edit and I need a shape that’s not a rectangle or I need to render multiple small areas not near each other. It would be great to be able to do this in one render pass.
good idea. In the 3dsmax version of v-ray, there is a function that can render only selected objects… I would be very happy if it was implemented in the sketchup version as well.
Ah yes, I knew I had seen this somewhere before. Definitely would like to see this. I can’t tell you how many times I run a re-render and then just sit there using the follow-cursor tool to get what I need updated. Especially when a deadline is looming!
