non-relevant alpha needed...
Hello there,
Corona has alpha forced to black, or forced to white, but how can we set alpha ignored for an object ?
I mean, sometimes we need an object to be alpha-seen regardless of the alpha of another object.
For that Vray has alpha going from -1 to 1 :
-1 : forced black
0 : ignored
1 forced to white
Regards
does making the object invisible to masks (in coronamtl advanced properties) help?
Exactly, many thanks…
Last need with alpha is to get alpha in reflexions / refractions (request alreay posted somewhere)…
Regards
The only problem I see with “visible in masks” option is that if there is an object behind it visible to alpha, the option doesn’t override it. What I mean is that would be great if we could have a way to remove it from alpha channel even if there is another objecto on the background covering it.
I guess this is the “always black” option, isn’t it ?
“always black” = -1
i gotta say after using Corona for a while i still think V-ray had this set up better
object properties were a lot easier to set up for proper alpha than materials
Setting this within a material can help in some cases : you can have 2 materials with different settings put into a multi-sub material, and animate a material modifyer… i use that all the time…
i suppose
everyone has their own workflow
for us it’s mostly masking objects, and being able to do that with object selection takes a lot less effort
In my last large project (billards configurator), i had to render out more than 150 000 png files… so all was set as a large animation for a specific model…
Animating the ObjectID is not easy, animating a material ID modifyer is simple… this is the reason why.
The topic stills needed : alpha to be ignored, so not “always black”, nor “always white”…
something like “alpha ignored”…
duplicate for the last request: Exclude A Visible Object from Corna Alpha Element - Corona for 3ds Max :: Requests - Chaos Forum
