Noname #1
Just testdriving the corona renderer and getting some great results so far.
There are a few features i would gladly welcome but by searching through the forum they seem to be already in the pipeline :smiley:
Two things about this scene:
The leaves are opacity mapped and are coming out with a bit of blurred edges. I also rendered the close-up shot without dof and there it was more noticable. Could ofcourse also have to do with my mat setup but nevertheless i didnt thought it was too problematic.
Had some weird things going on with the glassmat. At some point it had a lot of weird splotches in it which i believe were to blame on pushing the gain on a colorcorrection map on a bitmap too high. Also at some point there was some noticable colorchange through the glass which i cant remember how i fixed it but thought was very odd at the time. (also don’t seem to be able to reproduce it at the moment)
Anyways I am surely planning on doing some more scenes with corona in the future, great job on it so far :smiley:
Maybe you can reduce the blurriness of the leaves by increasing the opacity texture resolution. I think that the smaller the resolution is, the blurrier they will appear. The texture is probably being bi-linear interpolated, which smears the edges of the objects.
Ah yeah the blur in the opacitymap was at its default 1, that’s prolly it looking at some quick testrenders. I didnt really investigate it further because i didnt thought it was that noticable/bad.
For the glass mat i tried to reproduce what i meant, but i seem to not be able to :(. U can still see it a bit on the picture i posted on the top glass part i think, there is a blackish splotch on it which shouldnt be there normally and at 1 point there were more of them. But i’ve been tweaking the mat quite some and i thought at some point it had something to do with the gain on a colorcorrection on a bitmap in the refraction slot, but i seem to be mistaken. Ah well guess it was prolly some fail mat setting somewhere by me.
I used path tracer
I did two tests last weekend while watching a soccergame on the telly, a fully unbiased render during the first half and a PT+HD during second.
So both rendered about the same time( HD a little shorter) and afterwards comparing the two i could only see some real difference in the noise in the shadow areas. The HD one was quite a bit smoother already in those areas. Since I wasn’t watching while rendering i can’t say anything about the buildup of both images but I could conclude the HD being faster going to a more noise free image.
I am planning to play a bit with Corona again the coming few days so will do some more testing :smiley:
