Normal bump intensity not working, when using corona normal map.
Also, if i modify the texture itself (lower the bump) there is a clamping going on
The intensity bug was fixed already. As for the clamping, I suspect it’s just due to quantization when you make the gap between the highest and lowest value narrower (i.e. lower the bump).
