I am getting some black areas on my renders using the scans. Sometimes the whole object that has a scan material on it goes black. I am using the latest public release of Vray. I get a normal error in the message log when this happens.
Hi Tarik, to help you i will need some additional info
- What product you are using max or maya?
- What is the material that you are using (the name or something that identifies it)?
- Is the same happening if the scanned material is replaced by a normal material (to exclude geometry corruption)?
If the problem occurs only with scanned materials, i.e. it’s not caused by bad geometry and renders fine with vray material, please send the scene to support@chaosgroup.com with brief description
I am using max 2017 sp3, it works fine with a normal vray material. It happens with every scan material I have tried so far. I will send over the scene later today.
I’ll send the error message it comes up with as well.
I’m experiencing a similar issue when rendering an animation on max 2017 sp3. Some frames render fine, but many are missing the geometry with the VRscan material applied. Eventually the render errors out.
unfortunately the message does not help a lot, can you find the log file %temp%\vrayscannedmtl.log after the problem occurs and send it to us?
is the problem easily reproducible, i.e. is it happening every time at the same frame, or it appears randomly?
Apparently my problem was caused by a “Position Attachment” Controller on a Point Helper that was attached to a vertex on the object. It also periodically failed to render with a standard vray material.
To work around: I unchecked “Renderable” in the original Object Properties then made a copy that is renderable. Everything seems to be working fine now.
I’m thinking this is an error with 3ds Max (not vray).
-- contents of “vrayscannedmtl.log” pasted below --
start 17.2 9:37:6
render begin \\10.0.0.102\BHD_Library\3ds MAX\vrscans_library\Mtrl\fabric_blue_anisotropic.vrscan
load material \\10.0.0.102\BHD_Library\3ds MAX\vrscans_library\Mtrl\fabric_blue_anisotropic.vrscan old:
read tag 1 1
load calibration
read tag 6 1
read tag 7 1
read tag 9 1
read tag 12 1
read tag 15 1
read tag 19 1
read tag 17 1
material raw average:0.424898 0.715134 0.802383
material final average:0.424898 0.715134 0.802383 difmul:1.000000
anysotropy: 0.633046 time:0.090095
vrscan renderbegin \\10.0.0.102\BHD_Library\3ds MAX\vrscans_library\Mtrl\fabric_blue_anisotropic.vrscan
skip load
Load settings, n:77 mat:0000000049A50450
ccior:1.000000 mat:0000000049A50450
skip load
skip load
vrscan end render \\10.0.0.102\BHD_Library\3ds MAX\vrscans_library\Mtrl\fabric_blue_anisotropic.vrscan
render end \\10.0.0.102\BHD_Library\3ds MAX\vrscans_library\Mtrl\fabric_blue_anisotropic.vrscan
skip load
skip load
skip load
skip load
skip load
skip load
skip load
skip load
skip load
skip load
skip load
skip load
skip load
