There’s no additional bump in CoronaNormalTex map. If you’re using max’s native NormalBump map, no wonder why you’re getting wrong results. Normal maps should be connected via CoronaNormalTex only.
That’s exactly how I did the 2 images.
If however I put < MAX Normal Bump > which has both ( normal + Additional Bump ) … and then put that into < Corona Normal Tex > … it just doesn’t work…
As far as i managed to get some conclusion - the Additional bump - has no effect at all.
EDIT :
i also tried < CoronaMix ( Add ) - Bump( b/w ) + CoronaNormalTex - with Normal map inside > … still no result.
EDIT 2 :
Also , what format is best to save normal maps… I used BMP for this case ? Can JPG do the same result, or should I stick to some specific format ?
I don’t think the format matters much, although BMP is strange choice :- ) jpeg/png is completely fine in 8bit since the 3 channels provide enough spectrum.
But your request is valid, with current CoronaNormalTex reader you might not stack with additional bump, which would be great, as normal map is often best to avoid having tiny detail.
Since Corona informs me I shouldn’t be using Maxs’ own normal map system I’ve instead made a mix texture whre there is a standard B&W bump and then a Corona Normal Tex in the second slot, then play with mix amount but somehow I don’t think this is the right way. Could someone elaborate?
Any news on this front? I’m using daily builds, and tried exploring stuff that has been added since this topic was hot but no luck, I still can’t figure out how to use both normal bump and the standard bump together.
EDIT: This thread has over 400 views, making it the second most read topic on the page right now. Would it be possible to clear this out a bit, since now I’m resorting to silliness like a Blend material with 50% blend, the same material in both slots except the first uses Corona Normal Bump and the second uses the regular BW bump.
