Normal Map Bump Mult for Vray Mtl not working
Recently updated to Vray v7.10.02 using Autodesk® Maya® 2026.2 and immediately noticed that my normal maps bump value wouldn’t work correctly.
Even with the bump mult value set to zero it looks like it’s set to one.
Note: The problem only occurse when using tangent space normals mode.
Attaching a small scene with the problem.
normalMapVray7Issue.zip (2.33 MB)
It’s not a new issue. We already have it logged (internal tracker ID: VGPU-5818 ). I’ll add a bump on your behalf. Otherwise, the workaround is simple: Create a VRayBumpMtl for the bumping and use its bump multiplier instead.
Thanx for bumping the issue. It would be great if this can be handled soon. For us this issue is a show stopper. We’ve got approx. 6000 maya files and a lot of them are shared props in many scenes so we can’t use the workaround
