normal map doesnt fit the model
Hi. I was testing corona render when this strange thing happened.
When I first open this scene and I hit render the normal map on the sofa shows as in the image. Then I go to the material editor and I display the normal map in the viewport and it shows perfect. Then I hit render again and the normal map is perfectly working.
The normal map came out from Zbrush and I’m using a blend material with two diferent materials using the same normal map… any idea?
you may see the right images on the gallery: First test with Corona - Corona Common :: Gallery - Chaos Forum
Do you use CoronaNormalTex or 3dsmax one?
I’m using the CoronaNormalTex, and I used the materialconverter to convert the materials from Vray.
ok, then there is a 99% chance this is caused by a bug that was already fixed and wont be present in the next stable release/daily builds :wink:
