Normal map renderized incorrectly on the CPU
It seems that V-Ray CPU is not rendering normal maps correctly.
Apparently, GPU does.
I understand there are things that don’t work on GPU that do work on CPU, but how can something work on GPU and not on CPU?
Another detail is that for the normal map to render properly, I had to raise it to extremely high levels of 1000 cm.
It would seem that it switches to Object Mode when you migrate to V-Ray CPU.
Hi @prv_works
What V-Ray build are you using? (screenshot About V-Ray menu)
Are you able to reproduce this on a new, simple scene (cube, light and a V-Ray material with a Normal Map attached)?
Does every normal map leads to the same behavior? If it’s just this one, how was it created?
Hi, how are you? I’m on Blender 5.2.2, Kubuntu 24.04 with NVIDIA 580.178.04, X11.
The build is the latest one from a few days ago, 7.4.2.
I’m sending you a scene with the problem only on cpu compute.
Textures are packaging in blend file.
By the way, it would be nice if you could raise the 10 MB upload limit, since with that I can practically share nothing on the forum.
tnks!
Hi, I looked at the scene. The main problem is the Bump amount in the V-Ray material node. It’s 1cm and it ends up as 0,01 in V-Ray which V-Ray GPU multiplies in. Which explains the need for having a multiplier of 1000 in the Normal Bump node. So in your scene 1000x in V-Ray GPU should correspond to roughly 10x on V-Ray CPU. I logged an issue and we will start hard cording the bump_amount to 1.0 when explicit normal is used.
Hey, thanks for replying.
I understand, I checked my Amount values and yes, it looks good in both now, which leads me to the conclusion that if I want to migrate a project from CPU to GPU or vice versa, this would imply much, much more than being careful with current GPU restrictions and eventually correcting some specific material. Switching from GPU to CPU would imply having to look at every single normal map, which can be 100 or more in a truly complex scene.
This leads me to ask how well my RTX 4070 Ti with 12 GB of VRAM would work in a medium, medium-large production context, with out-of-core enabled for textures.
Is the GPU really worth it even considering some percentage drop in speed due to out-of-core, or is it more recommendable to render everything on CPU from the start?
GPU + out-of-core vs CPU from the start?
tnks!:+1:
