Normal map
Hi corona users! how can i insert a normal map into a corona material.?? maybe it’s something stupid to ask.. but i cannot find the way.. what is the correct way to use a normal map inside corona? can you help me with that?
i’m getting the normal map from substance loading the bitmap2material file.. but then where do i have to insert it ??
CoronaNormalTex
yes but, how i use it ??
so, i use normal map into coronaNormalTex Input,… then where do i have to route the output??.. into the Bump slot ?
exactly
thanks keymaster..!!
