I searched for the solution and saw several answers about changing gamma but nothing worked…
Even if gamma is set-up wrong, you should still see normal map effect in your rendering. Probably the issue is somwhere else. Maybe normal map intensity is set too low (normally it should be set to 1.0 in material as well as in Corona normal map node), or maybe map isn’t plugged to material (checkbox in material’s maps rollout). It’s hard to tell what’s going on in your scene without seeing at least screenshot of material in question.
Thanks for your answer!In one picture i show how i export maps from SP.In the second picture i apply the material,but when i put the normal map nothing happens at all.The color map works fine.I tried with arnold and scanline and normal map works fine.I also tried importing it with gamma override and selecting"add gamma input".What should i do?
I had tried these before and nothing worked,but i found a solution.I applied a “physical material” instead,with “corona normal”,the normal map was applied but it looked faded…I then checked “add gamma to input” and everything is fine!.The corona mtl had the problem?I have no idea…
That’s strange, which Corona version do you use?
5,hotfix 2
Can you try loading the same normal map, but saved in a different file format than TIF? There was some issue with TIF in the past, which should be already fixed in the newer versions of Corona (I am not sure if in V6 or only in V7 dailies).
