Normal Maps in Corona C$D
Is it possible to use a normal map in the bump map area in corona c4d? or is there another way to use normal maps?
Create a Corona Normal Shader in the Bump slot and place your normal map in there. There is also a slot for an additional bump map.
And don’t forget to enable Flip Y (green) if need be. :wink:
