North Dakota Elder Care
Suggest this view next time… It should let them see everything.
I’m not liking the DOF btw. Way too distracting.
ROFL with the suggested view… The DOF is physically accurate; I used the vray camera. The whole model isn’t modeled well, so I wanted to have everything out of focus, except for what I added more detail to. The Revit model was rough and every corner I took needed fixing.
I still have to work on UVW’s and modeling… I don’t have a cap on one of the retaining walls and I need to move the CMU texture around. The stone columns also need to be fixed because the texture doesn’t continue around like it should.
there is truth in looking at something in grayscale. it looks spooky! Hopefully the owner will opt-in for some landscaping and warmer stone color.
The DOF is accurate, in the sense that it makes it look like a miniature. Seems your fstops are way too low.
to get the look I was after, which might not be a good look, was an f-stop of 1.
That’s why your DOF looks so strong, you’d be hard pushed to find a physical lens that goes lower than a f-stop of 1.4.
If an architectural photographer was to take the same picture, they’d most likely shoot around f8.
The DOF is physically accurate; I used the vray camera.It’s possible to enter non physical values into the physical camera :slight_smile:
it would be nice if something notified you when you went outside of a physical environment. Not just the camera, but materials, too.
It’s not outside of the physical environment, it’s just rarely seen…http://us.leica-camera.com/photography/m_system/lenses/5915.html
It may be that your FOV is too large for an f1 stop which makes the edges of your image look way too blurred and hence, unrealistic. I don’t think a wide angle lens can go that low.
Two questions from a beginner:
1. I’ve seen that orange glow you have in your first image at the left on quite a few renderings. Is that rendered light/V-Ray settings or is it post-pro? Either way, how do you do it?
2. I work in Revit and render with V-Ray (usually for Rhino, simply because that’s what I know… trying to learn 3ds). What workflow do you use? The models I use are quite large (largest right now is an ~450MB Revit file). Furthermore, you said that the Revit model was not very good. What would you ask the architect to do to improve it for your use?
Thanks for any advice you may have!
What would you ask the architect to do to improve it for your useI’m not sure I would ask for anything. The architect’s model serves a different purpose. I have learned not to expect anything more then a starting point. The model saves a little time, but not a lot, since I have to spend a lot of time cleaning up bad geometry.
I’ve seen that orange glow you have in your first image at the left on quite a few renderings. Is that rendered light/V-Ray settings or is it post-pro? Either way, how do you do it?The lens effect is done in PhotoShop. I usually do a Google Image search, researching for the feeling I want to convey, and try to recreate it in post.
Thanks for the responses!
I’ve heard renderers say they don’t bother asking for anything from architects. That’s why I’m asking, though. What WOULD you ask for? Can you be more specific about “bad geometry”? Does that mean coplanar surfaces for example? What else? We use Rhino a lot in our office. For our design purposes, glass can be a single plane… until we render. I’m trying to slowly adopt and encourage a style of modeling that makes rendering (or sending to renderers) easier. You admit that you spend a lot of time cleaning up the model. If you could reduce that time, I imagine you could give your client drafts sooner and have more time to develop and improve the rendering. Or you could simply be more efficient and have a higher profit margin. :slight_smile: Are there Revit-specific things you find are always a problem?
Thanks! I like that effect and would like to add it to my arsenal.
