Not Embedding tonemap layer into image output sequence
I’ve got this image sequence that doesn’t appear to be including the filmic tomemap layer into either .jpg or .png output sequence - specified through the frame buffer tab. Fyi, I had the blending weight in the VFB set at .35 when the sequence ran.
Is this because of something I’ve not setup correctly? Thanks in advance for any solution… Rendered through CPU
Hi @rusteberg
Can’t seem to reproduce this, can you let us know if there are additional adjustments particularly in the Filmic tonemap’s settings? You can export the whole layer tree preset and forward it to us, or alternatively - send a stripped version of the scene with the issue reproducible. Please reach us through our contact form and make sure to mention this thread in the email, thanks!
