Not enough disk space
When rendering with DR Node, I am overflowing the drDump > C:\Users\XXX\AppData\Local\Autodesk\3dsMax\2018 - 64bit\ENU\en-US\plugcfg\corona\drDump
folder and running out of space on my C drive :frowning:
What can I do to make these files default to another location?
You can simply turn off “retain exr’s” option if you are running out of space on your drive.
Thank you!
