I’m new using PhoenixFD and I have a problem to run my very first test.
I press play after I placed my first Phoenix Box simulation in the view port.
Now MaYa is getting me this message (see image attached).
I bought a special disk drive for the simulations, but how can I now move all my future simulations to that specific disk drive?
Yes! And it is only a 12 Meters x 5.7 Meters
I just only press for the very first time on the button “create Phoenix FD Fluid Simulator”
Draw a box with the dimensions on the top and when I press Play “Start Simulation” is the message I get.
Hi Ihno!
Well when you came from MaYa FX is a bit different
After I saw the Videos that Georgi post I understood - that you need to select objects before start to simulate something.
But thank you now Im on the right path after your comments
Next step is to understand if I can do the simulation with my nVidia card (GPU) at the moment is running nice with the CPU, but I will like to stress also the GPU.
Actually there is a GPU Shade preview, but let see if I can run everything in my GPU
