The Camera map per pixel seems to have quite limited functionality and I don’t think it can be used in this scenario. I tried several approaches including Scanline and max lights setup but it doesn’t work.
Maybe it would be possible to get what you want using Camera map per pixel in conjunction with a V-Ray light material or a regular material with mapped Self illumination slot ?
Thanks for getting onto this! Self illuminated won’t really help, because we’re illuminating environment fog, and the render times would become prohibitive. Even without camera map per pixel, using a map in environment/screen mapping mode should work, and it’s not - looks like the light doesn’t respect this type of mapping. It would be great if we had control on the UVs the light is using - maybe pick them up from an object or something?
You can see how the light is not using the environment/screen UVs.
Fixing that would be great, hotfix would be awesome. Giving us control over the UVs would be even better, for the longer term.
Tried in VRay RT CPU - the bug is not there, the light does respect the env/screen UVs. But it is not illuminating environment fog when texture is on, so we can’t use it Not sure if that’s a bug or a limitation.
Have you tried placing a plane at the appropriate location, map the texture onto said plane, then render-to-texture and use the resulting texture as the texture for the light?
Unfortunately this is not at all easy to implement. Will see what can be done about it, but for the moment, the workaround suggested by Art48 with baking the texture should work.
