so I have my render farm of one machine going. but I have run into a small snag.
when I save the irradiance map to file and the use the map to render with, the slave doesn’t use the map. I saved the map to a folder that both machines can see. the server can see it no problem. As long as I have a new map each frame everything is fine on both machines, I’m not really sure what I’m doing wrong.
which version of vray?
sorry, figured it out and forgot about this post. I wasn’t hitting a check in the network job assignment window that says Include maps. ![]()
thanks for the reply though. ![]()
