nuclear war splotches
hi,
in some of our max2013 projects that we have to update in 2015/vray3 we get strange big splotches. same file renders perfect in max2013 with vray 2.4
colour and size changes at every rendering.
using max 2015 sp3 vray 3.10.03 DR
any ideas what to search for ? never seen this in 11 years…
thanks thomes
We are having similar.
Are you using the new opacity mapping mode for your leaves? (stochastic I think)
I’ve seen something similar occur due to there being some Architectural Materials somewhere in the scene from a Revit import.
thanks for your help boys !
all evermotion/itrees/forestpack trees/bushes out of the box… fast look shows all on “normal” opacity mode, no changes to the old files…
but i found one autodesk generic in the scene…
i try out if it´s getting away. if i don´t come back to this thread it´s okai ;-))
Hello Thomes,
These colorful splotches are very typical, when you have unsupported materials. You can also try V-Ray scene converter, it will convert all scene materials and raytraced shadows to V-Ray ones.
I’ve also had problems similar to this when using vray materials. The problem however was due to the output amount in a bitmap texture pushed above 1 (I think it was around 2).
@dlparisi
Can you send us sample scene and tell us which version of V-Ray do you use with it?
Sorry, not really as I don’t have a scene right now that is exhibiting the problem. I “think” the problem was on an old evermotion flower model that had the pedals pushed to be really bright. It was certainly when I was using 2.4 but most likely 3.x also. The problem usually exhibited itself in blurry reflections producing super vivid colors similar to what the OP had (it’s a little hard to tell where the color is coming from in the original post images).
Ok, thank you for the feedback.
hello tsvetan,
can you send me upload link for about 500 mb zip file.
i can´t track it down…
thanks thomes
Just send us email on support@chaosgroup.com and we will provide you access to our FTP server.
Please add the link to this thread in your email.
hi tsvetan,
…hiding the multiscatters and all their dependencies does not make a difference. i have also the render errors.
also disabling embree did not help. at the fourth rendering i got the same errors again
Thank you for the update, unfortunately even with the latest nightly makes the same problems, but I have some more test to do and hope the reason for this issue will appear :slight_smile:
hi tsvetan, thanks for your tests. i think you wanted to say taht you hope that the issue will dissappear ?? no?
here something i found at the area. it seems similar problem
There were some invalid materials in the scene which might be the root of the issue.
The issue seems to disappear once the V-Ray Scene Converter has been executed.
Please right click in the scene viewport, select V-Ray Scene converter:
Then turn on all check-boxes and hit Convert button:
Save as the scene as a new file, run a test render and let us know if there is any improvement or not.
hi Svetlozar,
sorry for repeating that late, i was in easter holidays.
i tested it today and converted the scene as you said with all three points ticked.
…same problem as before.
did it work for you, if you render it 5 times? all okai for you?
thomes
Hello Thomes,
Actually the issue is because of the Multiscatter objects, we have seen this with other our clients. Unfortunately it is very random issue and on some of the machines, that we have does not happen even after 10 renders.
We will talk with our developers and most probably will report it as a bug.
Our problem turned out to be due to an incorrect value for our SSS shader “phase function”. Setting this to 0 fixed the problem for us without breaking the look of the material, but this may not apply to other scenes.
p.
What was the incorrect value? If you still have the scene, I would very much like to take a look at it.
I think it was something in excess or less than 1 / -1, so perhaps beyond the range that would be physically correct/possible.
I think we’ve already sent the scene in to your support team; I think Pete Addington (lone robot) was the one to submit the support request. I can find out for you if required. I don’t think the people that looked at the scene picked up the shader setup as an issue. They seemed to think the latest nightly fixed the issue. We tried that but the issue remained until someone here tried adjusting the SSS settings.
p.
