I think you need to unpremult(iply) each pass, combine, and then premult(iply)..
Maybe share a screen grab of your comp, or attach some basic files of your issue to troubleshoot.
- a dirty solution is to take that reflection pass and do an errode on the alpha to eat off that fringe.
You need to render your main object against black, in case your background is not black this will also contribute to the problem. As cheerioboy pointed out though you need to first unpremult everything then do your layering, then primult it again by the alpha at the end of the comp.
Can you send us a sample Max/Maya scene files along its nuke-composition and render elements for investigation?
Have you tried to work with deep-exr files? They usually provide a more elegant and easy solutions to these hallo-issues.
It looks like if you only want to have a single rendered image, you need to be more gentle with the grading. If you want to push the grade that far, you should look at separating your objects into different renders, background & object, with the object rendered on a black background/alpha. You’re getting issues because either way you do it with the single render, using a multimatte mask, or using premult & unpremult, your object’s edge is blending with a lighter colored background. So those pixels on the edge will go brighter when you raise the gain or multiply up.
