Nurbs Surface Problem - 2 side things don't work
Here’s some images.
As you see, mapping onto Nurbs model(Alias Work) doesn’t work.
I tried to search for the solution 'bout that, found one - Double Sided Material Type thing, and that didn’t work, too, as you see in the last two images(flipped faces changed…)
I experience these situations occasionally when I do the modelling with Rhino, Alias and etc. Using ‘Normal’ Modifier - unify on, flip off - in Max works, but the faces change little awesome…
Comments please.
ps. Sorry for my English
Anybody who has a comment about this…?
The setting in the image was wrong… or something…
Max seems to have some problems with meshes imported from other programs. Do a search for Rhino and you will find some solutions. :smile:
I have the same problem when I duplicate an already grouped object.
Delete your node before duplicating or delete node after and group again.
This will resolve your problem (in my case it work… I hope it will be the same for you).
Can´t you just select those parts of the surface and flip their normals ?
i think thats all thats needed here … have turned show normals on ?.. you need to unify them .. so they are going all in the same direction
he can, but max transform the nurbs to mesh when fliping.
Not the greatest solution but you can transform the surfaces to high quality mesh, then unify/flip them. Its not a clean solution but is something.
I have the same problem here.
It normally doesn´t need to be transformed to a mesh when flipping nurbs
normals.
If you are lucky (depending on the import/export) Then you can
select these flipped surfaces (not faces) on subobject level and just flip their normals.
It´s very unlikely that some normals are flipped within a single nurbs surface. But you never know what the importer does :?
The only solution I ve found is to flip the normals once you’ve transformed the nurb into a mesh. If you need to change it you have to come back to rhino… You can check the surface orientation in rhino though, to make sure it’s ok before you import it..
