Hi to all, there was a similar topic from a few years ago but it was closed without answers so wanted to ask. There is a strange behavior that i can’t understand exactly why. I use in my normal workflow Lightmix, VFB color correction layers, and Nvidia denoiser as the preferred denoiser. Mostly I render with a CPU engine. After the render is finished or progressive at the reasonable level I stop the render if it is not the final work and apply denoiser. What I realized is, the denoiser changes the colors and the overall image significantly depending on the level of the denoiser. it looks like denoiser gets false information and blends it with the original image. If I add the denoiser like 0,250 it looks a little different but when I raise the level image gets too much different than I want to see. I can not say where this starts to happen but I believe it has a connection to saved VFB presets. This happens mostly after working with many scenes and applying different presets. But couldn’t find a way to use still presets without having this though.
Not directly related but another thing is, I want to apply OCIO profiles but the directory section is locked, and couldn’t find a way to enable it.
I use the latest version of Rhino 8 and V-Ray by now on Windows 10.
I would appreciate all suggestions.
Cheers!
