Nvidia denoiser ingniors denoise amount in virtual beauty pass
Here is my separate post for my second issue with denoiser. First post: https://forum.corona-renderer.com/ Intel denoiser - visible seam
When I choose Nvidia denoiser, activate multi pass, virtual beauty and set denoise amount to 0, the pass still gets denoised.
It happens only when Nvidia is activated.
This is clearly an issue to me, even it’s the same in max. Nivida denoiser has also denoise amount where you can tweak the blending between 0 and 1.
I would assume that it should be possible to save both versions.
The workaround now is to do it manually, but this is not satisfactorily.
Thanks and have a happy day :smiley:
Internal note:
We have the same issue logged in 3ds Max:
(Internal ID=297111950)
Hello and thank you for reporting,
I was able to reproduce this issue just as you said - issue is passed to the developers to look into.
Thanks,
Jan
C4D (Internal ID=642528148)
