nVidia denoising error
Good evening my friends,
i am using Corona version: 3 (DailyBuild Sep 20 2018)
Full-speed, Non-debug, MaxSDK 2018
Build timestamp: Sep 20 2018 07:21:48
and today i encountered this error while rendering:
Error encountered during denoising.
Unknown error (Details: Function “_rtCommandListExecute” caught exception: Failed to launch DLDenoiser post-processing stage. DLDenoiser run method failed with error -4711.)
I am working on this scene from over a week on this build, no errors prior.
I suspect this error happens when using Free Camera instead Corona Camera.
Is this known bug/limitation?
Also:
is there a way to create Corona Cam from perspective view? Some demanding perspective match going on here.
There’s a button on the Corona Toolbar to create a Corona Cam from the active Perspective view.
The NVIDIA error is most likely related to memory (and running out of it). Resolution size and GPU memory will likely determine that - what resolution are you rendering to, and how much memory does your GPU have?
First of all, please try with a newer daily build: https://coronarenderer.freshdesk.com/support/solutions/articles/5000570015
Secondly, we should have a new version of the Optix denoiser soon, with better error reporting and lower RAM usage.
Thank you for your answers.
So i have 1060 with 6gb of memory.
I used denoiser with scenes exceeding 40GiGs of RAM with no errors :smiley:
The error occurs only when using max’s Free Camera (Psychical and Corona are ok)
No problems with the free camera here. Can you share a problematic scene with us? Chaos
