Anybody running Quadro M6000 card? looking for the best settings for sketchup and enscape?
I’m running a Titan X here at my workstation, which in terms of enscape and sketchup should be the same as the M6000. It’s hard to say anything about performance, as it depends on scene complexity and screen resolution. But you should be able to run most things on high/ultra with decent framerates, and vr should be fine on medium/high in most cases… again, it ALL depends on the scene.
This scene, as an example, is only running at around 5-10 fps in ultra in 1440p:
… where as this scene is running more than 50 fps on the same settings ![]()
so, experiment with it, and se what works in what scene…
what i CAN say, is that the 1080 ti in my own computer at home is almost twice as fast in most cases ![]()
The Titan X (Maxwell) should be lil faster than the M6000 as they have the same chip but the Titan X has higher clock speeds.
The new Titan X (Pascal) should be up to 60% faster compared to the M6000/Titan X Maxwell.
https://babeltechreviews.com/battle-titans-pascal-titan-x-vs-maxwell-titan-x/3/
You are totally right
I should have clarified that I was talking about the Titan X (Maxwell) of course ![]()
