NVIDIA Quadro P2000, 5GB Graphics Card
We are currently in the process of replacing some of our Revit workstations and the graphics cards that are installed as standard are:
I appreciate that these are slightly older graphics cards, but are more than adequate for Revit (and as always we are on a tight budget). I would be interested in how well these cards run / cope with Enscape.
Any feedback would be most appreciated.
If budget is tight then drop specc’ing Quadro’s immediately. And then again, even if it’s not.
A 5GB P2000 retails at ÂŁ400 - you can pick up a 8GB GTX1070 for that money.
I agree with @snowyweston
Thanks for the feedback guys, I will pass onto our IT guys.
@Trav72 , generally, depending your budget (and in case you don’t specifically have to acquire a Quadro), I can recommend a NVIDIA RTX 2060, 2070, 2080 or the RTX 2080 Ti, but the 2060, 2070 and 2080 will already be able to run Enscape fluently and you’ll also be able to make use of VR with these cards. :slight_smile:
Why would you recommend a GTX 1070 when the RTX 2060 is both cheaper, better and employ specialized ray-tracing cores that will soon (currently in preview version) be used by Enscape to further increase the advantage…?
Even a GTX 1660ti will be on par with the GTX 1070 for half the price.
any specific reason as to why you recommend the old generation of gtx cards, and not the new RTX breed, with support for hardware rtx that enscape soon supports? personally i would recommend a 2070, 2080 or 2080ti :slight_smile: These are MUCH newer cards!
Yeah you’re right @Herbo :slight_smile: I adjusted my response - the Quadro P2000 is around 400-500€, but even the RTX 2070 can be had for that much. In the long run it’s definitely better to go with the newer RTX cards, especially if one is not on a rather tight budget!
I was unaware of such budget-conscious RTX offerings - and more than happy to be corrected !
