They are positioning it as a “pro-sumer compute card”. What does that mean exactly for per-core rendering speed in RT/GPU? Does full FP64 performance mean faster GPU rendering in RT/GPU? Will it render faster core-for-core than the GK104?
Bottom line is that at 999$ if it has twice the rendering speed (or more) in RT/GPU than the GTX 580 I’d be very interested..
Will it render faster core-for-core than the GK104?Not sure on this one; it runs at lower clock speeds, so core-for-core it’s probably a bit slower. But, it has more VRAM.
Bottom line is that at 999$ if it has twice the rendering speed (or more) in RT/GPU than the GTX 580 I’d be very interested.Yes, we’ll need some actual benchmarks. I think it’s expected to have about 85% of the performance of a GTX 690, but that’s not official. I’m not sure how that compares to the GTX 580 either.
Right…
Hmmm…well, as I have seen it, 85% of a 690 (essentially two 680s) will be considerably slower than two 580s. Consider that a single 680 is already ~5% slower than a single 580, double that, subtract the 15% and there you have it. Twice the money for about 75-80% of the speed. Not real exciting, render-speed wise. I imagine it will be quite interesting for folks who are building a new system and want/need more VRAM though…
They never should have given us a taste of the rendering capabilties of the dang fermi cores!
This Titan sounds quite interesting but NVIDIA had to f@k it up. They blocked 3rd party mods meaning no 12 gb vram version The 12gb would be gone b4 any1 would even preorder them
This might be the breakthrough hardware for GPU rendering.
Its (kind of) affordable for freelancers and with 6gb RAM you can load most of the normal production scenes.
I really look forward to get this one.
This is all about vram. I don’t really care at all if it’s going to be even 50% slower than a 680. The fact that I could potentially fit some proper production scenes into vram means that I might actually be able to use RT for images, at least as part of production if not as the final renderer. Quite a big deal, this… We need some concrete benchmark results and perhaps a brave Vray Forum user to test one out and let us know how it goes. I’m a little reluctant to drop what will probably be £1000 on this if it’s going to come with issues. My main concern would be heat from long renders.
Fantastic! Look forward to trying this out soon. Are you planning on testing a Titan yourself soon Vlado? Would love to hear your own feedback and see some benchmarks directly from RT.
I might be able to get hold of one to run some tests. Been testing the 690 recently so I will be able to give a like for like result.
On the subject of benchmarks has the results list been updated at all? I posted a few render times with the 690 but I have never seen them added to the results list.
V-Ray RT 2.30.02 - Driver 306.97 - 1m 39.4s
V-Ray RT 2.30.02 - Driver 310.70 - 1m 39.2s
V-Ray RT 2.30.02 - Driver 310.77 - 1m 39.8s
V-Ray RT 2.30.02 - Driver 310.90 - (didn’t make a difference even though the NVIDIA driver update said it would :/. It did however improve iray by about 10%)
