Object Based Fog Setup
Fog setup not clear, can’t find any clear instructions in the docs.
So this is as far as I get.
(env fog works fine)
vray_adv_43003_houdini18.0.460_687aa72_7666
Houdini 18.0.160
is the opacity of your surfaceshader set to 0?
Hey Jim,
as Ronald has mentioned above, the opacity on the V-Ray material should be set to 0 for this to work.
Best regards!
I tried all possibilities in that regard. I guess it is possible that the vfb didn’t update and I needed to stop and restart the render etc. Will try on Monday…
Thanks guys.
