Object Cast/Receive Shadow Setting
I would love for there to be an option to turn off casting and receiving shadows for an object or material as currently exists in Sketchup, so I can avoid things like this fire’s shadow
Hi @hhowerton & welcome to our forums,
you could set the transparency value of the fire material to something like 15-25% - then you won’t have shadows, but a similar look. Note however that emissive and transparency both at the same time are currently not supported.
Hope that helps :slight_smile:
