I’m making renders for light and I just wanted to know if there was a simpler solution to what I do.
I used 3 light sources for this spotlight.
1- a light material behind the glass lens that lights up all that is behind the lens, including the lens.
2- a corona light circle just before the lens to light up the lens holder only
3- the corona light with an ies file and that occludes the lights just under the spotlight module.
For some reason I get some noise in the scene from light sources that are exclusive the objects
I was thinking to put a corona compositing tag to the lens holder to remove reflections, you think it could help reduce the noise?
