Object Properties
Is it possible to add additional items to the object properties in the next version? Or only one items - Visible to Camera? BlackSurface on screen. Material Emissive in Attachment.
EmissiveLightNotShow.zip (68 KB)
Hi vincent1976,
This option (as well as some additional ones) is on our to do list and should become available in the future.
The plan was to introduce it in the material options though. Having it in the object properties will also be considered.
In the meantime you can do the following:
> Assign an Override material to the plane
> Leave it’s Base Material slot empty
> Plug your Emissive material in the Reflections slot
This way you should see the plane reflected but not directly visible to the camera
Regards,
Konstantin
