I want to create a view with “create a view” and then I get this? And no view…
Could you please make sure you’re running our latest release? If that doesn’t help or you’re already up to date, could you please re-install Enscape? That may help already. In case it doesn’t, updating your windows as well as the graphics card drivers could instead, if you’re still not successful with creating a view, please kindly submit a dedicated feedback report as described here.
In the submission form, simply briefly describe your issue and/or add a link to this thread. ![]()
Thank you in advance!
An Object is an instance of a Class , it is stored some where in memory. A reference is what is used to describe the pointer to the memory location where the Object resides. The message “object reference not set to an instance of an object” means that you are referring to an object the does not exist or was deleted or cleaned up. It’s usually better to avoid a NullReferenceException than to handle it after it occurs. To prevent the error, objects that could be null should be tested for null before being used.
if (mClass != null)
// Go ahead and use mClass
mClass.property = ...
else
// Attempting to use mClass here will result in NullReferenceException
