Object Scaled to Zero crash
Hello!
One thing I stumbled upon: When you animate the scale of an object to zero corona crashes on render. I guess this only happens when motion blur is on. And I suspect this might also create problems with particle systems generating particles over time.
Greetings!
Daniel
What version are you using? I remember fixing this a while ago. It is possible I overlooked some case. Maybe it would be best if you could post a scene where it happens?
Thanks for looking into this. I sent you a PM with a scenefile.
Daniel
ok, it was a really specific case caused by animated object. I fixed it
