Hi, I’m wondering if someone can clarify for me what the ‘disable’ parameter does in the objectproperties node as I can’t seem to get it to work, either that or it doesn’t work how I’d expect.
I’ve checked the documentation ) and it’s not mentioned.
In this example I’m applying objectproperties to several objects to remove primary visibility and GI, but then later on I’d like to disable the node.
So my thinking is that ticking ‘disable’ would stop the objectproperties node from taking effect and use the default settings of the objects, i.e. all set back to ‘on’ for visibility and GI.
Matt
