I’m using Sketchup Pro 2022 and Vray 5 last update (2.4) windows 11.
Some Objects imported from 3dWarehouse are not showing in Vray > Y did explode them and they finish to show in vray but it’s impossible to work that way! I won’t be able to make any further modification.
Furthermore, the result with or without the denoiser is the same > the denoiser seams not to work.
can someone help me please?
I had similar problem before, changing object material can solve the problem..
Thanks.
Do you have the same issue as me concerning the denoiser?
Denoiser always works for me.. Some models exported from other 3D programs are making problems when importing into sketchup, deleting object material and using new material solves invisibility issue some times..
Hi emilie_coudray,
Can you please point us to some example 3d Warehouse models that we can test with?
Can you describe the exact steps you took when the denoiser failed?
Keep in mind that interrupting the render can cause the denoiser to not get executed at all.
Regards,
Konstantin
