I have recently had some scenes with an issue not showing the custom reflection objects in renders. I commonly do renderings of homes that want to see the specific site in the reflections and I’ll map photos on a plane. When I render without using backburner, it renders fine, but when I submit the render to network rendering, sometimes the reflection image doesn’t show in the reflections. See attached examples.
- object properties have been checked for visibility
- layer properties have been checked for renderability
- material is a v-ray light material with the photo in the map slot, compensate for camera exposure is checked.
Any suggestions? It is only when network rendering that I have the issue. No other materials or objects have issues rendering.
*** edit - I also found that the object with the image itself doesn’t render. If I want the image to show up as a background it renders white, with no photo reflected, or shown beyond as a background.
