Managed to find time to finish my latest personal project inspired by a trip to Southeast Asia. The building is based on Kyriakos Tsolakis Architects design. The whole landscape and forests are done very quickly and could be improved; also, there are some lighting conditions I´d like to try, too, but I´m not going to work on it anytime soon if at all. More images can be seen on https://www.behance.net/AndresSaarnak.
Amazing Visuals. Can you explain more about project your process of working, which tools you used and how much time it took. would love to see more of your workflow.
Lovely environments!
But surely you would have a shot at night time with a star filled sky when doing a project like this? ![]()
The terrain is displaced using a free height map I found from the web. I wanted to use a real height data from an actual place in Vietnam but didn´t get it to work.
There are four ForestPack objects- higher forest and lower bushes are separated for both foreground and background. Tree models are pretty random, foreground should be much more detailed…There would be a lot to improve, but I´m trying hard to adopt a habit of calling a project finished as fast as possible and just render images out and move on. I have plenty of projects I have improved endlessly only to get tired…and no images to show.
I tried some scripts to model a road into terrain but these didn’t work and I just brute-force modelled it.
It took about a month. After work, just a few hours a day and several days in between each time I worked on it. The building actually took much more time than terrain, because I changed it a lot.
Hehe, true:)
