I can’t be the only one that has set up a scene where you’ve been working with it for a week or so, rendering out multiple animated sequences, everything looks great until… You open it up the next day and something looks a little off. So you start looking at render settings, maybe Environment and Exposure settings, and then finally you start looking at the lights. Everything appears A-OK in terms of the Properties/Modifier Stack except: There will be a light that is no longer actually lighting the scene. You move it, crank up the lumens, whatever; no change. It’s just dead.
Of course, you can go back and Merge/Replace the light from an Autobak file, or from an incremental Save, but that doesn’t exactly mean the problem isn’t one.
I assume there is no actual solution to this, but I figured I’d ask anyway. Cheers
