Running into a problem here,
mabe someone can help.
I’m trying to sim an ocean in a geometry. Also in a pretty small scale (Cylinder is about cm 30 in size)
All fine, but i’m not able to kill all particles around the cylinder with the particle tuner.
Do i miss something? see screenshot and scene attached.
Hmmm, haven’t looked at the scene yet, just noticed that the distances are pretty narrow - 1.0 and 0.1 are in voxels, so maybe the chances that particles enter this range at the moment the tuner works is very low, and so the particles skip it?
Ohhh, I see what’s going on with the Tuner - you are using a render cutter for the mesh, but in fact there is real ocean simulated inside the entire Simulator.
So the waves keep creating foam and splash - they show up for one frame and then die immediately by the Tuner.
So there are two things I would suggest:
- Render time solution - add a cutter to the particle shader as well, and these particles will not be visible
- Simulation time solution - add the Cylinder as a birth volume to the splash and foam so they would not get born outside it.
