ocean sky reflection outside camera flustrum with distortion
It’s being looked into, thanks for the report.
@frodopytlicek there is a workaround, thankfully: i traced the issue down to the phoenix simulator, *not* the displacement texture itself.
Your ocean should render fine so long as you use a standard geometric plane and a displacement mod with the ocean texture on it.
The bug in the phoenix ocean is being looked into (will update here with the JIRA ticket number later.).
Yes I know about this workaround but unfortunately we have simalations there, not only flat ocean plane. Its really just about the subdivs of off-screen mesh, im 99% sure :slight_smile:
It has to do with the padding to the frustum edges, normally 20%, that seemingly Phoenix doesn’t implement to the same extent as the rest of V-Ray.
That of course influences the amount of geo being generated.
Btw isn’t somehow possible to combine displaced plane with cap mesh ocean sim?
@georgi.zhekov will know.
Unfortunately there is no poper automatic way, but how about fading the shader of the water with a gradient around the edges of the simulator and then placing the plane with the displacement around that?
Depending on the camera view and the lighting this migh work or not, but it’s the only thing that comes to mind, besides doing it in post with masking.
I did somethink similar before but it did not work well, but I’ll give it a try again. Thanks
it might not be this simple, but what about rendering with overscan, and cropping to your delivery size?
See post #10 saying the same thing :o and associated replies.
It is that simple, but the OP has other factors making it not that simple.
Filed as PHI-7541.
What is this Lele?
This is the internal issue number under which the problem is logged into our bugtracking system. It makes it easier for us to track which problem is related to which forum thread.
Ah ok it used to look differently :slight_smile:
It’s a Phoenix bug, not a V-Ray one, so it’s filed differently. :slight_smile:
Hi I want to ask if there is some progress in this topic?
None yet, unfortunately.
