my first ocean test render . totally random objects ![]()
looks great, but the local detail is too uniform ![]()
yes thanks :),this was more a water surface interaction with other objects test:P, it always gave me a dark edge with refracctin, I masked the opacity with ao to try and fix it. but i guess this works better with Bidir?
Not good. If you want to use procedural maps as bump use cellular mixed with fractal noise or something similar. This looks like ocean on a rainy day. ![]()
Is it really procedural? All the waves are equal, it seems to be a bitmap, try to make it better, maybe you are using a bad mapping.
About the dark edges, what are you talking about? I don’t understand, are you talking about the water that becomes gray or what else?
no bitmap its a noise map.
What i mean is how do you get the water to be totally transparant.
The part of the objects that are under water are darker .I want to remove that . ![]()
hi Can you please share your water material.
Im trying to do water for a swimming pool
are they darker because are under water?
Sorry i dont have the material anymore. I tried to copy this effect: zap's mental ray tips: Nice Water with mia_material (Arch&Design) without the caustics.
think i ended up with a ambient occlusion in the opacity slot to soften the dark edges around objects. hope it helps
