Working with Phoenix 2.0 Keira Nightlie 22733 I tried the PhoenixOcean Texture in the Transperancy Texture slot of the coffee steam example. Looked great, then changed it to a liquid and added the same texture as a Phoenix texture. I think this created some kind of circularity whick locked up Max Do you have an example file using the Ocean texture?
i didn’t understand what exactly happens, but is it ok now?
Yes, earlier the memory usage cycled every few seconds. Any tips on using the Ocean shader?
just set it in the vray vector displacement modifier. there are still no scale corrections, and if you increase the amount this will affect the sharpness too.
