Sorry if this is a basic thing, but i’ve tried several options and online help etc, but i cannot make the transition between the grid and the ocean mesh to be even… Default settings for ocean sim already have this issue by default… Also rendering settings are default. Displacement is off too. Tried other initial fill up values and matching the ocean level value with it but same issue. Tried longer sims and different resolutions, always same issue…
you have to adjust the rendering ocean level precisely, equal value with the corresponding simulator parameter is not enough, it’s just a good starting point. in your case you have to increase it
Is there any formula to achieve the exact level, or just trial and error? Sounds a bit counter intuitive until you find the right value for example 52.354. Specially when you have a high density simulation, and to simply do a test render it takes a bit of time to check the values. Sorry if this sounds a bit of a basic question, i’m a new phoenixfd user, so far i’m very excited, but this little problem with ocean rendering caught me off guard
Yup, the thing is that the liquid in the fishtank could slightly subside or raise up during simulation and whether this happens and how strong the effect is cannot be predicted and depends on many different factors, including what geometry is there in the container. We could automatically calculate the average height of the container for each frame, but then the ocean would start bouncing up and down during animation We are yet to figure a more convenient way than adjusting this manually…
if there was a formula we would integrate it in the level calculations
unfortunately the simulation equilibrium level is hard to predict and that’s why manual adjustment is needed.
Ok so i’m having this issue with the ocean where the boundary initially goes up and down for a while, what would be the best approach to have a stable ocean mesh boundaries? Right now just a simple tank without any object or interaction, even after 250 frames the ocean mesh keeps going up and down, it never stabilizes…
I even tried SPF 4, 6 etc.. always same issues… Max 2015 btw… I’m trying in 2017 soon to see if it’s some random issue.. Already saw other ocean tuts on phoenix 2.2 and there were no problems, so i’m trying to guessing now
Same issues with max 2017, i simply cannot have a seamless transition between grid mesh and ocean mesh, no matter what ocean level, SPF value, and resolution.
Here’s a screen.
edit: I opened the scene ship from the 2.2 tutorial, did the sim, and same issue happened, while on the tutorial it didn’t happen.
No, i didn’t touch anything. Just pressed sim… You can download and try it and see if u have the same issue has i do, right now i can’t do anything with ocean mesh because of this and we already started production…
Tried with that version and same issue, didn’t change anything… It’s even more noticeable in animation, it just goes up and down inside the grid.
Also i tried the newest ocean tut with just the cylinder and same thing happens, there’s no way around to solve this issue. 2nd screen i tried to manually adjust the ocean lvl, in this frame its ok, but in animation it keeps going up and down and you can clearly notice it in animation, so it’s unusable…
Funny thing is in several youtube videos from 2.2 ocean, i can never spot this issue…
