I’m trying Chaos Player but each time I load my exr I need to search my config.ocio, is there a way for Chaos player to have OCIO loaded at player startup as default lookup table, even if OCIO declared as environment var I have to telle player to use OCIO
Right now, you have to specify it each time, even if the OCIO variable is defined.
This has been requested a few times already so it’s high on our to-do list.
It would actually be great to have the last used colorsetup (be it ocio or not) remembered/used. Most of our projects use ocio (with acesCG to sRGB display transform) but a few use none ocio setups. Even when working on multiple project at the same time (with different color setups) it’s most likely to hit the correct settings when using the previous used setting. Hope this makes sense.
