OCIO Frustrations...
Apparently I don’t get how to use OCIO color management. Don’t know what it is. I’m in 3ds max 2026, using Vantage 3.0.2. I set my colorspace to OCIO in MAX, it’s set in Vray and when I go to Vantage things just fall apart. I’m majorly frustrated. If I use the Auto setting in Vantage, looks good, but once I change it to OCIO everything gets super contrasted. What’s the deal?! See attached images.
The OCIO in 3Ds Max 2026 is new(version 2.4) and not supported by Vantage yet. The issue is logged in our system LAV-2308
Try with OCIO 2.3 and ACES 1.3, set it with a system environment variable. It should work just fine.
Other than that, OCIO color management is not needed unless you receive or share assets with others in a VFX pipeline based on OCIO color management. The OCIO-ACES workflow has many issues, you could explore it to learn the technicalities but don’t expect it to bring any realism or benefits to your renders. It is recommended for most people to stick to the standard sRGB rendering
Best,
Muhammed
