OCIO substitution for Vantage
Set of luts for Vantage - a fix for missing ocio support.
ACEScg and sRGB scenes
OCIO config for VRay included
48 luts for Vantage + ocio config
luts in Vantage require Highlight burn adjustment = 0.0
8 view transforms and 3 displays (sRGB, gamma 2.2/BT.709 and rec1886/BT.709):
- aces-rgc: ACES 1.0 SDR-video RGC view transform for environments without OCIOLook support: https://docs.acescentral.com/specifications/rgc/
- filmlook01: traditional film emulation
- filmlook02: black and white film emulation
- cinemalook01: classic teal and orange look
- cameralook01: famous K1S1 lut from ARRI https://www.arri.com/en/learn-help/l…t-generator​
- AgX-Punchy: view transform by Troy Sobotka: GitHub - sobotka/AgX: There Be Kraken and Dragons · GitHub
- Unity-neutral: Unity neutral tone-map from Maya’s ocio config
EDIT:
- ACES 2.0 rev060 view transform
OCIO config from this post: https://forums.chaos.com/forum/chaos…er#post1221708
OCIO LUTS for Chaos Vantage available here (not a freebie this time):
how to:
samples (acescg scene, Vantage vs VRay):
filmic AMPAS:
Vantage lut aces-rgc vs default 3dsMax aces:
Vantage luts filmlook01 and cameralook01:​
Vantage vs VRay comparison with all the view transforms:
edit: do not worry about the red “laser” light in acescg scenes - this is a stress test - it’s pretty much infrared territory. if you tone it down a bit into PBR range it will look nice - unless you are using any filmic or default aces from autodesk.
mP_OCIO LUTS for Vantage v2:
+ ACES 2.0 rev060 view transform
Vantage vs VRay - ACES 2.0 rev060 gamma 2.2 display (sRGB primaries scene):
Well, let me be the first (after almost a year, really?!) to say THANK YOU for this, Marcin. Epic work. Working great in Vantage, and a brilliant way to get a 1:1 tone mapping result with Corona within 3ds max. Cheers!
