I noticed that when applying an OCIO LUT under colour mapping, you then lose all EXR dynamic range when making colour and exposure adjustments. I’m assuming thsi is because the LUT (or view transform) is being applied before the colour corrections when in fact it should be applied at the end.
The only way around this is to apply the LUT on an adjustment layer at the top of the stack instead of on the clip itself. Would be nice to not have to do this though.
Hi there,
Are you seeing the pixel info showing clamped colors, or is it really visible clamping?
Just wondering what’s the case, as we had an issue where our pixel info would not display colors above 1.0 (which was fixed), but the actual color value was correct.
