if i use ocio workflow in 3ds max and render animation in vantage, save output files to .png, does the output file contain the color space(profile) that i have set in 3dsMax Vray frame buffer (save in image) in my case aRGB
Hi, s_gru,588
No, OCIO/ACEScg are not currently supported in Vantage and the output images are in sRGB color space. We plan to add support for it in the future and we have it logged under LAV-588. I will add your request to it.
Alexander
i will continue this topic with the question - how to setup OCIO workflow with 3DsMax + Vray + Vantage? what setings should we use in all software for color management, input color space, display settings and so on.
i understand that it is not easy to set up for different software versions. lets talk about 3DsMax 2025 + Vray 7 + Vantage 3. or 3DsMax2026 + Vray 7 + Vantage 3.
i used to work with gamma 2.2 workflow. but latest updates have OCIO Acescg support and workflow and some tutorials say that it is the way to better results.
i set up 3DsMAx+Vray for OCIO acescg setup, but in vantage viewport my HDRIes work very differently in a bad way
i appreciate any tutorials, articles, advises.
thank you
Ooh… good to know. I was about to upgrade to 2026, but since Vantage doesn’t support ACES I’ll wait.
Vantage does support ACES.
i was just asking about proper settings for correct render and viewport
Can you show images or share a scene that we could test with?
You’ve confused us
Are you supporting it? Or not?
I’m confused too.
Hi all,
Vantage does support ACES render color space(since 2.5.0 in June 2, 2024) and OCIO(since 2.7 in February 12, 2025). The rendering color space in Vantage is determined from the color space the vrscene is exported with, you cannot change is inside Vantage. You can check the current color space from File>Scene stats>. The OCIO is controlled from the viewport bar from the Monitor icon dropdown on the right(
). If you have set your settings in V-Ray for 3dsMax for the ACES workflow properly it should work for Vantage as well. If not - please send us the scene to investigate it using the Chaos Help form with a link to the forum thread: https://support.chaos.com/hc/en-us/requests/new You will have to include all asset files.
Alexander
So I can update to 2026 and use the OCIO workspace?
