Odd issue during render....
So, made a scene with Max 2021 and Corona 7 hotfix1, everything looks fine, but out of the blue, materials were changed in rendering (and were normal at the viewport), whenever I isolated an object, the material changed, if I rendered more objects, the they changed again, and at one point the HDRI got all blurry and weird.
Some prints attached (I did not changed anything a part from unhiding and hiding objects, happened to anyone? Also sometimes a block renders completly white.
Hi, can you please clarify if you are using googledrive for your scene assets?
(Report ID=CRMAX-848)
for some of the textures… yes. Other ones were on my local hard drive, should I save they all on the same folder as the max file?
I am afraid for the moment it might be prudent to either have them on a local or network drive, not necessarily the same folder. This is a bug that was discovered rather recently and we are hoping for a quick fix as soon as possible.
Alright! Thanks!
Have you experience the same issue with newer versions of Corona?
